How to change bandwidth and sample time in OFDM ?
kappasm
I have implemented a system OFDM 2K with band of 8 MHz, style DVB-T. Using a system clock of 64 MHz everything works perfectly. Now I should be able to decrease the band OFDM to 7/6/5 MHz using the same 64 MHz clock. To get the bandwidth of 8 MHz in 2K (1705 active portant), simply clock output data from a IFFT at period of 7/64e6 = 109.375 nS.
In that way or with that technique can reduce the clock out for obtain 7/6/5 MHz of band ? Without necessarily changing the clock 64 MHz ?
Any idea ?
Thanks.
Kappa.:
Re: OFDM switch band ...
Yes you need only the 64 MHz Clock. You should be able to change the bandwidth by changing the sampling period.
Thanks m_pourfathi,
But how to change the sample time ? Changing the clock scheme ? Do not distort the signal ?
Example:
Band     |     Clock Scheme    |  Sample time
8 MHz    | 1010101010101010    | 7/64e6
7 MHz    | 1101010100101010    | 8/64e6
6 Mhz    | ???                 | 7/48e6
5 MHz    | ???                 | ???
You can give me an example ?
Kappa.
