How to change a vsource using Ocean or Skill?
safwatonline
EGYPT
hello,
i have a circuit containing a vsource , i use this source as a dc in calculating the noise figure and as sine in calculating the IP3,
i want to know how to change this source by ocean or skill and "check&save" so that i could be able to do noise figure simulaton followed by IP3 simulation automatically
regards
Re: ocean or skill
I dont think one can change the sources beacause they are in the netlist. One alternative can be place a vsource where u can specify the frequency term, DC voltage, Ac amplitude as variables and make ac and frequency to 0 when u want this to be as a DC source
    safwatonline
Re: ocean or skill
If you got to the point in analog verification to skip over the famous, clicky Artist you should use either Perl or Phyton to assembly netlists, testbenches and control simulators and verification extractors.
There to many limitations in ocean/skill if you have to do serious verification.
    safwatonline
