gaom9
Full Member level 4
I have a question about how to calculate the layout geometry size of inductor by changing the parameters of it?
Here the parameters include Inner Radius、Coil Turns、Width、Spacing.
Thank you!
Best regards!
Added after 50 minutes:
There is a link for it:
http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=util_inductance_calculator
But the parameters in it is not the same as above.
Loop of wire with square shape for example, the parameters are: number of turns, width of the rectangle, wire radius, relative permeability of the medium
How the set the parameters, please?
Thank you!
Best regards!
Thank you!
Best regards!
Thank you!
Best regards!
