How to calculate the Frequency .......
Guru59
Full Member level 4
Hi all.......
If i we have One Block that transfers data at 1Mbps .......
Then what is the Frequeny of the Block...
Thanks
Whether it is serial or parallel link, if serial then your clock frequecny should be 1 Mhz else 1Mhz/bus_width, It depends also on the block designer to use what frequency.
Hope this helps,
Well, frequency at which your block is working can by anything really, Mpbs cannot really tell it. Depends upon your architecture:
Kr,
Avi
http://www.vlsiip.com
