how to calculate the drain cap in cadence
Julian18
Full Member level 3
Full Member level 3
Hi, there
I want to get the drain cap of a common CS MOS amplifier, after dc analysis, the cadence calculated cdd, cdg,cdb,cds, but i dont know which one i should use to calcuate the bandwidth at the drain node, suppose the drain node seeing some resistance.
Thanks.
I suppose you should use Cdd, which is the sum of Cdb+Cds+Cdg.
remember to sum the capacitor of the loading transistor and amplifer transistor
