How to calculate the checksum of a NMEA sentence?
UroBoros
Advanced Member level 2
Cochin - India
nmea crc
Hai
Inorder to input a command to my GPS module I want to calculate the checksum of that NMEA sentence. How to do that?
Any software available to calculate the checksum of a sentence?
Or how to that manually?
With regards
picstudent
how to calculate nmea input checksum
Calculating and Validating NMEA Checksums
Error correction and detection in NMEA data is handled through the use of checksums. A checksum is a two-character hexadecimal number, located at the end of each NMEA sentence, representing the "two's complement" of the sentence:
$GPGSA,A,2,29,19,28,,,,,,,,,,23.4,12.1,20.0*0F
In other words, each byte value between the dollar sign ($) and asterisk (*) is XOR'ed.
Attached is an example in C-code ..
Regards,
IanP
    UroBoros
to calculate 8-bit checksum for a hexadecimal
Look at this :
char buffer[82],buff2[6];
uint8 i,crc,s;
snprintf(buffer,sizeof(buffer),
"$GPGGA," //MESSAGE ID
"%09.2f," //UTCTIME
"%09.5f," //LATITUDE
"%c," //N/S Indicator
"%011.5f," //LONTITUDE
"%c," //E/W Indicator
"%d," //Type of fix
"%d," //Number of SV
"%.2f," //HDOP
"%.1f,M," //MSL Altitude
"%.1f,M," //GEOID Separation
",0" //DIFF Age, DIFF Station
,92725.00 //UTCTIME
,4717.11399 //LATITUDE
,'N' //N/S Indicator
,833.91590 //LONTITUDE
,'E' //E/W Indicator
,1 //Type of fix
,8 //Number of SV
,1.01 //HDOP
,499.6 //MSL Altitude
,48. //GEOID Separation
//Calculate crc...
crc=0; s=strlen(buffer);
for(i=1;i<s;i++)
crc^=buffer;
//Add it!
snprintf(buff2,sizeof(buff2),"*%02X\r\n",crc);
strcat(buffer,buff2);
Add the CRC definition for NMEA :
The NMEA checksum is an XOR of all the bytes (including delimiters such as ‘,’ but
excluding the * and $) in the message output. It is therefore an 8-bit and not a 32-bit
checksum for NMEA logs.
Chris. :D
    UroBoros
