How to calculate the 3rd harmonic distortion in Cadence?
princerock
Junior Member level 2
I'm designing an op amp and want to calculate the HD3. The input signal is 1KHz. I found that there's a "dft" function in the calculator. But how to set the variables in it? ("from", "to" means what?) And how to get the HD3 from the dft result?
btw: how long should I run the transient simulation to calculate the HD3?
Thank you for your help in advance!
you run .tr
to: end time
you at least need 3*T, this is to say, for 1k Hz, you at least need 3ms.
run longer time such as 30ms
from 5ms to 35ms
You can also run a fourier analysis. It uses the Fourier Integral to calculate the distortion products.
