asw1n
Junior Member level 2
Dear all,
I am designing a deferential feeding antenna.
A wide band 180 deg power divider is used to transform a single-ended signal to two deferential signals which are anti-phase with each other.
and the two deferential signals are fed into the antenna via two coaxial ports.
I used HFSS to get deferential S-paramenters of the two coaxial port.
Regardless the effect of power divider,
can anyone tell me how I can calculate the single ended s-parameter from the deferential s-parameter?
