how to calculate setup & holdtime from liberty file
sakshi gupta
Full Member level 1
India
can somebody explain me with example how we can calculate setup & hold from synopsys liberty file ?
yx.yang
Full Member level 4
ZhuHai, GuangDong, China
there is a good explaination in the help menu of the tool itself......
You can also see the *.lib for detail.
Basically, its based on look-up tables. The input is usually input trasition and output load, the look-up table output will be output transion and signal delay.
Of cause there will be some filter if the input data not in the *.lib look-up table (ususally is the case).
