xbtxbt
Member level 2
- Joined
- Oct 12, 2004
- Messages
- 44
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 560
pin diode power
I designed a RF ciucuit in which there were some PIN diodes to decide a operating RF path.The RF signal will pass by a PIN diode when it's path was choiced.It worked well under a -10dbm signal power generator.But when I added up the RF signal power to 20Watts,the performance of the RF circuit collapsed.The PIN diodes I used is MA4P7104 of M/A company which works with a Rs less than 0.5ohm and the power dissipation under a constant 25°C environment is 3Watts.I don't know why the circuit can't work and I don't know how to calculate the power admit of the circuit.I wonder if someone would help me.TKS!!!
