How to calculate maximum frequency of a circuit?
kumar_eee
Advanced Member level 3
Bangalore,India
How to calculate the max.freq of the ckt?...
The delay between 2 adjacent flip-flops + Delay of combo
Is it correct?....
Re: Max frequency
generate reports with a clk period of zero.
then max freq = 1/max delay in the design
Re: Max frequency
kumar_eee:
The max frequency is calcuated like this:
tp = tsu + td + max(tco, th)
tp: period of the clock frequency
tsu: flip-flop setup time
td: the delay include wire delay, combine logic delay
tco:the clock to output delay of flip-flop
th: the hold time of flip-flop
max(tco, th) : the maximum between tco and th.
Re: Max frequency
Hi Kermit,
You said,
Suppose assume,
tsu: 1ns
td: 3ns
tco:1ns
th: 2ns
max(tco, th) : the maximum between tco and th. - is it max(1,2)=2 ?????
tp: ?
My question is where exactly this setup-time in this equation comes in to play, because what i have read is hold time is independent of clock frequency. Then how come hol-time(th) has come into this equation?
Added after 1 minutes:
CORRECTION
My question is where exactly this hold-time in this equation comes in to play, because what i have read is hold time is independent of clock frequency. Then how come hol-time(th) has come into this equation?
Re: Max frequency
In the view point of waveform, Setup time edge should be at the front of hold time edge. In other word, setup time edge and hold time
comprise a window which has left edge as setup edge. This window is
data transition forbidden window. When inside window, it would violate
setup or hold time.
So left side edge(setup edge) is where the fastest the logic can run which means setup timing plays role in determining max Freq not hold time.
Nandy
www.nandigits.com
Netlist Debug/ECO in GUI mode.
Re: Max frequency
setuptime plays role in performance of system
but if we wont meet hold , system will fail. so hold time plays role in functionality itself rather than performance.
what i mean to say is even if by some chance u don't meet setup after tapeout of the chip, because of changes in delay beause of temp changes caused by dynamic power diipitation...we will have option. beacuse we will have option to set the frequency at which chip has to run.
Re: Max frequency
The Maximum frequency of operation is determine by the slowest path or the worst case delay.so it is the summition of the
t clock to q delay + combo delay and setup time of the other flop.
But while analysis we have consider the best case where hold time comes into picture. If for the given maximum frequency the
T(hold) <= t(combo delay) + t(clock to q delay) . If this eqation doesn't satisfy then circuit will fail. and in this case we have introduce the buffer in the data path to increase the delay . which will automatically decrease the frequency of operation.
Added after 2 minutes:
Max frequency
Generally it is that. But don't miss the setup and hold constrain.
Re: Max frequency
carrot said:
Hi Kermit,
You said,
actually tp > tsu + td + tco-max
why th is comming into picture?
Re: Max frequency
hi
th comes into picture only when ur hold time is more than clk2q delay in ur FF.under,such a condition,ur data should not change for that hold time part as well.so,i hope u get why hold time comes up in the picture..
regards
Re: Max frequency
still, i can't convince that " Th " comes into picture for setup violations.
can anybody provide material or link for that explanation..
Re: Max frequency
Hold time needn't come into the equation. The maximum time that your combination logic can take to do its computation is only limited by setup, skew, clk-2-Q delay and the time period of the clock signal.
This is the reason why on increasing time period of the clocking signal you can actually correct the operation of a circuit that was faulty because it couldn't meet set up time.
However, all said and done, the minimum time that your combinational logic should take to compute (if not computation, at least put a dummy delay) is a functional of skew, clk-2-Q delay and the hold time.
Hope this clarifies
Re: Max frequency
hi ,
the freq at which the circuit does not violate set up time with ur consyaints well defined gives u ur max freq..
Max freq is adjacent flop delay plus comb delay..
Adjacent flop delay include c2q delay and setup time.. thats it..
regards
