How to calculate library setup time and Hold timel?
ramagandhi
Newbie level 6
Newbie level 6
Banglore
hello every one,
can any one explain about How to calculate library setup time and Hold time?
Thanks in Advance
RGR
by using spice simulation the min delay (setup time) required between data and clock so that data is captured to output is calculated.
DATA __ __/```````\___
CLK _/``\__/``\__
OP _______/`````
for example, the simulation is done in number of steps by decreasing delay between data and clock. in each it verify the output (should be 1 in above case). in this way the min time between between clk and data pin gives the steup time.
