how to calculate delay in cadence?
muffassir
Member level 3
Planet Earth
how to calculate the delay of inverter rc extracted layout ..
i calculated the delay from test ckt schematic ..
i want to calc the delay after rc extraction to see the effects of RC components on inverter (from rc extracted layout view)
please give the steps from which view i should start.??
Thanks in advance!!
If this is Assura, then you first need a clean LVS, then you run RCX, then you
prepare the av_analog_extracted view, then create the config view for your
simulation testbench; open it, start analog environment and select that view
for the inverters and then proceed with simulating.
