how to caculate the Rds_on of Mosfet?
TERADYNE
Newbie level 5
rds mosfet
in datasheet, show the Rds_on is 0.18 ohm by design gurateen, for IC designer
how to caculate the Rds_on?
mosfet rds
plot IdVd at Vd=Vg=Vmax.....
rds on mosfet
From your information, I guess the MOSFET is in the deep triode region(vds«2(vgs-vth)), so you can use the expressions about the RDSON.
Ron=1/{µCoxW/L(Vgs-Vth)}
Meanwhile you can simulate the rdson of the mosfet by the simulator.
Best wishes!
rds_on
Mos Rds on is "not linear" , you should define Load
& output current Vol .
mos rdson
Rds_on means the D-S resistance when mosfet turn on,I think the mosfet should be saturation status.
mosfet rds on
plot V/I curve and calculate the ratio
what is rds on mosfet
Rds(on)=Vds/Ids. Normally Vds=0.1V, and Ids is your specified drain current.
what is rds of mosfet
when chips designer design this chips, the design will
caculate the Rdson, while not measure by Vds/Ids.
I want to know how to caculate the Rdson.
