How to burn a program into PIC 16F84
xylynn
Member level 2
how to load program on pic16f84a
Dear all,
I'm a beginner of using PIC.... Now i need to burn a program into PIC 16F84..
Would anyone like to guide how to burn?
Thank U very much:|
how to burn pic16f84
Use Icprog tool and load the hex file into the pic.
how to insert the hex file into pic ic
1) You must have a programmer (hardware) to connect your PC to the PIC to be programmed. There are several programmers available for purchasing or you can build it yourself (lots of schematics and designs in the web). The easier and most simple is the JDM programmer, which connects to the serial port. The best programmers are those with USB connection.
2) With the programmer circuit, you should use a control software, which usually comes together when you buy the programmer. If you have preferred to build one, for example the JDM, you can use the ICPROG or the WINPIC800 softwares (they are free and easily found for download in the web). There is also the MPLAB IDE from Microchip which supports all oficial programmers from the manufacturer of the PICs.
3) All burning softwares allow you to load the HEX file and write it into the PIC flash memory. If you are building a ready project check if the HEX file is provided. If not, try to look for the ASM file and use an assembler program (for example the MPASM that comes with MPLAB from Microchip, also free to use and download).
serial port pic burn
Here is one hardware programer for IC-prog, it's for serial port and doesn't need source power. it must be connected to the serial port of a PC, use a DB9 connector, the pins are indecated on ther right of the picture.
it's another for other PIC's and EEPROM
burn hex into pic
U should have WinPIC800 to load the hex
U also need a programmer to program
maybe u can made or buy the programmer
