How to build your own wireless mouse?
selvaraja
Full Member level 4
reciver 27mhz mc13135
hai guys,
do anyone have any idea have build your own wiressless mouse ...where to get their parts ...tools do use to design ....and so on.....
Re: wireless mouse
I'm intrested in this topic too.
I thought about it alot, I think best way is to buy a low cost optical mouse &
make it wireless, it just need a FM transmiter, something like MC2833.
At the begining I wants to use digital format but it's too complicated for this simple
comunication. I do some funny tests! [becuse I havent got required tools like oscilloscope], it seems like PWM modulation ,so a FM transmiter would be enough.
POWER , the main problem!
we just can talk about it during the work, actualy, if you wants to countinue. ?
regards
Mosh
    selvaraja
Re: wireless mouse
Interesting problem. I was working on a solution to it and gathered much information at one time. Here is some of what I learned:
1. Most wireless mice are at 27MHz since this is truely an international band free to use.
2. The TX is very simple, a xtal oscillator at 1/2 the TX frequency (~13.5MHz) that has a simple one transistor oscillator and an output stage that multiplies the frequency by 2 followed by a frequency selective simple LC filter at the TX frequncy. Another device is used as a varactor (very simple, typically just another transistor) in the xtal tank used to FM the oscillator based on the ucontroller drive.
3. The RX is typically an FM demod part such as the Motorola MC13135/13136 (very good receivers!) driving a corresponding RX ucontroller. There are several components used for this including the channel xtal, IF filter and quad coil. Not as simle as the TX.
4. One thing to note, the antennas are loop antennas set with a capacitor to resonate at the RF freuquency, but at 27MHz will have a loss of > 30dB! Not very good but it helps to limit the range!
Ron
Re: wireless mouse
Intresting information Ron,
where you fin them, can you refer some links? i want to know more detailed info's.
& another things, have you got any sample shcematic?
and another problem, for hardware hanshaking we will need a sender & a receiver
in each side, or we should instal the driver manualy, or..., have you got any idea?
thanks in advance
Mosh
Re: wireless mouse
Do you have any ideas how to improve the range with simple modifications? I've got the problem that the range of my wireless keyboard&mouse is limited to about 2 - 3m. But i need ca. 4 - 5m. So perhaps adding an external antenna?
Mik
wireless mouse
using ic to set the frequence to transmit and recieve.
wireless mouse
I had done myself with IR signals, take care of the +- pins of IR diodes.
Re: wireless mouse
check agilent site for mouse design
or you can easily design one with cheap optic mouse and rx/tx modules
