If you have a few billions rupees you can make a certified one to supply to a customer or for a few hundred dollars make a fake one for your room. **broken link removed**
That black square thing is the incoming breaker, that will switch the board off if the current exceeds a certain value, say 200A. The meters are to monitor the outgoing current and voltage and perhaps the neutral current or even the earth current.
Frank
