How to build a filter inductor with 600uH of indutance rated 10A using a PC-ATX power
fjpompeo
Advanced Member level 1
Brazil
How do I build a filter inductor with 600uH of indutance and rated 10A using a PC-ATX power supply filter inductor core (the rounded one yellow that filters +5V, +12V, -12V, -5V output)?
I need know the number of turn and wires gage(I guess a set of three or four to avoid skin effect).
This will be used as output filter in a russian adjustable 2Vdc-22Vdc / 0A-10A 20kHz smps using TL494.
Regards,
Fernando
inductor 10a
First, you will need to find out what is the standard inductance factor (AL) of your core ..
Wind, say, 10 turns of any copper wire on your core and measure the inductance ..
Use the attached formula to calculate AL: L is inductance, AL is the inductance index of the core, and N is the number of turns ..
Apply the same formula to calculate number of turns for 600µH and this time use ≈2.5mm² copper wire ..
Regards,
IanP
inductor filter 10a
IanP,
The part that puzzles me is that there must be a limit caused by the core as to how much current you can send through the coil before the core reaches saturation.
Do you have some words of wisdom on this topic? How do you test this parameter?
Thanks in advance...
inductance al
Inductor/inductance with magnetic core always makes headache. In most case, we need no inductor with precise inductance value. In the other hand, for more accurate inductance value, we have to try and measure then wind it again and again. You can easily regconize that inductors made by a professional manufacturer always are tiny and accurate, while the one made by any amateur basing on the popular literature is big and far from desired value.
To fjpompeo, I have experiences with Russian electronic literatures, where in most case they always provide circuit diagrams with very detailed information on parts, especially inductors and transformers. Basing on their data, you can easily modify parts to adopt your practical situation.
If you can post that Russian document, I hope may help you. Maybe in their document, Russian words are not familiar to you so hard to understand.
nguyennam
inductor 600uh 3 a
Hi nguyennam,
See attached PDF file.
600uh coil
fjpompeo, Russian words above L1=200 to 600uH say:
"This circuit is not critical to inductance of the inductor. Any inductor, which is wound by wire of 1.5 to 2mm diameter on a ferrite core with the cross section of 2 to 4 cm2, is suitable.
Hope this clear for you.
In case you need to know anything more in this diagram, just simply let me know.
Goodluck
nguyennam
Re: 600uH 10A inductor
Dear nguyennam
Very thank you for your reply to my question. If you need anythink related to portuguese language count with me.
Regards,
Fernando - Call sign PU2PLL - Brazil
Fernando, I am very happy could help you anything. Thank you very much for your goodwill, I will bother you once I need Portuguese translation.
nguyennam
