In designing the telescopic opamp:
1. can i make the input and output common-mode voltage the same, e.g. 0.9V for 1.8V power supply, because i need to design a pipeline adc, so the common-mode voltage for each stage should be same (is it a must?).
2. after i calculte the gm and id for each transistor, how can i bias them (the most involved point is to bias the three NMOS in a stack, e.g for the NMOS input telescopic), is it the right procedure that firstly using the ideal "vdc" to drive the gates, then designing bias circuit to bias the gates? or you can tell me some generic methods to do so.
can you give some heuristic advices?
