Nov 19, 2018 #1 N northumber82 Member level 3 Joined Jan 6, 2018 Messages 66 Helped 2 Reputation 4 Reaction score 2 Trophy points 8 Activity points 564 [SOLVED] How to beta tolerance in LTspice? There is a method to set a percent value tolerance of beta of BJTs models in LTspice? I used function "Worst Case" and "Monte Carlo" for resistors and capacitors: Code: Worst case function: .func wc(nom,tol) if(flat(1)>0,nom*(1+tol),nom*(1-tol)) Application: {wc(nom,tol)} Then run with: .step param run 1 10 1 Then what for the transistors beta? There is anything? - - - Updated - - - Ok sorry, I answer myself because I found the solution 2 minutes later: Editing the transistor model and put the same function "mc" or "wc" to the parameter "Bf". Example: Bf=420 After: Bf={wc(420,0.05)} Tolerance of 5%
