How to assign material in HFSS 9.0 ?
fussylogia
Newbie level 5
material assigning
I m new user of hfss 9.0 and I have little but unsolved problem.when i creating my design I did not assign materials to some of the objects and in the end i cannot.When i select the object, assigning material option becomes inactive.How can i solve this?
Re: material assigning
In HFSS 9.0, the material of the unassigned object is vacuum. you may double click the object that you want to assign material, and a dialog box will be appear, you click "vacuum" , and then you can assign material. oK!
    fussylogia
You go to history tree. In the model tree, there will be a subtree for unassigned materials. Go to the unassigned material box: Right-click-->Edit-->Properties. Click on material then a list of material will appear you choose the one you want to assign or you can create a new one if you know the epsilon and other material properties. Then click Ok. That way you can change the material properties later on also. Hope it helps.
Regards,
Rex
    fussylogia
