How to assert IBIS model to component in PSD15.1
Serg_SV
Member level 3
I want to assert IBIS model to component in PSD15.1.
What editor can I to do it?
ipcore
Member level 2
IBIS model
Analyze->SI/EMI sim->model
mars_dong
IBIS model
You should convert the IBIS model into Cadence's DML format use Modelintegrity first!
Serg_SV
Member level 3
Re: IBIS model
Hi mars_dong,
I can not find Modelintegrity in PSD15.1. How are you propose convert the IBIS model into Cadence's? IBIS model is it *.txt file, isn't it?
Serg_sv.
binu G
Advanced Member level 2
Bangalore
IBIS model
hi,
iam looking for the ibis model for the Xilinx vetrex II pro i could not find it in the website. the one found was not matching with it pins.
iam using a 1152 pin fpga.
Binu g
Serg_SV
Member level 3
Re: IBIS model
Hi Binu g,
I dont know where look for your Ibis model, but you can try generate it model from Xlinx if in possible. For example in Quartus II I can generate any Ibis model for microcircuitry which I use.
binu G
Bangalore
IBIS model
hi Serg_SV
i got the model but it dont have the pin ref.
how to remap with the pin
binu g
Serg_SV
Member level 3
Re: IBIS model
binu G said:
hi Serg_SV
binu g
Ok, if you got Ibis model you can write pin ref yourself.
For this you have to list of model and type pin your chip.
For example for Cyclone ep1c6q240c8 I have several models pin 1c_cmos33_io_d12s, 1c_ttl33_io_d24s, 1c_cmos33_in. You must know which model corresponding each pin.
[Pin] signal_name model_name R_pin L_pin C_pin
1 IO 1c_cmos33_io_d12s
2 IO 1c_cmos33_io_d12s
9 VCCIO POWER
10 GND GND
value R_pin L_pin C_pin you can get from datasheet
binu G
Bangalore
IBIS model
Serg_SV
that will be bit difficult to assign 1152 pins.
is there any way to automate it .
binu g
