How to add shorting pin in IE3D
micro_tech
Member level 1
Member level 1
shorting pin in ie3d
Can anyone please give me a hint to add shorting pin in IE3D (MGrid) for microstrip antenna...?
thanx
ie3d shorting pin
Add vertices where u want to short .select those vertices and with the help of Adv edit-> Buid via connecting edges or in case buid via through selected polygons u can able short it.
Hi balaguru thavamani,
Thanks for your reply...
Before, I done the shorting of patch antenna by using the "Conical via"...
Is it the same (I mean in the results)?
And for the diameter of shorting pin actually how much it is (which also used in practical)?
Regards
Normally in Printed Antennas circular via (PTH) will be used.
and in case of dia it depends up on the frequency of operation and size of the
antenna.
Hi:
If you are building ribbon vias between edges on 2 different layers, you can use Adv Edit->Build Via Connection... If you want to build solid vias, you can use ENTITY->CONICAL VIA. You can also build the shape of the via as a polygon on a layer. Then, you select it and use Adv Edit->Build Holes and Vias from Selected Polygons. If they shape are the same, they should yield the same results.
best regards,
    micro_tech
