How to add one layer with number 14 and TEXTTYPE=10?
harryzhu
Member level 3
gds texttype
I'm using virtuoso and need to add one layer to metal1 for port label, but when I add one layer, I cannot find how to set its TEXTTYPE number, how should I do? Thanks for your help!
pandora
Newbie level 5
when u add the layer ,there is the env ,u can set it.
you can set dg or ll or by etc.
harryzhu
Member level 3
To Pandora,
Would you please say more detailedly? Thanks for your help!
pandora
Newbie level 5
other way:
when you export layout to GDS, you can set the TEXTTYPE number you want.
harryzhu
Member level 3
But I need to add such one layer and use it to add pin so that I can run LVS, If I haven't such one layer in my layout, if I wanna set the TEXTTYPE number when export layout to GDS, which layer should I set?
