krishnanice
Newbie level 5
Adding MOUNTING HOLES
Hi. I've made a PCB design and am trying to add the mounting holes. At first, I wasn't sure about how to do it. So, I thought I should add a mechanical part in the schematic and when I export the files I see the same in the layout. But, it did not work. It's giving me an error message that RefDes is missing though I have mentioned the part (in Part Developer) as a mechanical and specified M as the RefDes.
Well, if anyone know the simplest method of getting the mounting holes on to the PCB board, I would appreciate your suggestions.
I'm using Cadence Allegro V15.2
