How to add constraints in dc script to fix hold time ?
mic_huhu
Member level 3
How to fix hold time err
How to add constraints in dc script to fix hold time ? e.g. for multicycle 2 clock period
Re: How to fix hold time err
hi
you can delay the data wrt the clock so that the data does not change for a specified amount of time after the arrival of clock.
in dc you can use
dc_shell> set_fix_hold<clock_name>r
reoptimize_design -in _place
I think it is better NOT to fix hold time violation in DC, it is better to do it in P&R....Because the timing
model is more accurate...
For the multiple cycle path, you must set the constranint as followings:
set_multiple_cycle_path -setup 2 -from ... -to ...
set_multiple_cycle_path -hold 1 -from ... -to...
The second line is very important... (please refer to
DC manual..)
then set_fix_hold////
Hope help you...
