How to add a stimuli from a file to act on my circuit in Cadence?
safwatonline
EGYPT
How to add a stimuli from a file to act on my circuit (i.e. i have a certain waveform and i want it to be a act as a source to a certain circuit) in cadence environment
vpwlf verlilog-ams
Hello;
.Include stimuli file
Try to use ELDO or HSIM simulators
    safwatonline
ipwlf cadence
gafsos said:
Hello;
Can you explain in detail,plz?
Cadence
hey as i said i am using Cadence !!
Cadence
Try vpwlf or ipwlf sources (Independent Piece-Wise Linear Voltage/Current Source Based on File).
Type "spectre -h vsource" for command-line help.
There: "you can read the waveform from a file. In this case, you give time-value pairs one pair per line with a space or tab between the time and the
value".
Another way is using verilog-a/ams capability.
    safwatonline
Re: Cadence
You can reference to cadence spectre user guide.
Re: Cadence
you can make an cell with verilog A , and descrip the wave which you want , then add them to the schematic in virtuoso.
Re: Cadence
hi
i am not using cadence tool.
value".
thanx.
