how to add a resistor model from a model card
ramy_maia
Member level 2
AA
hello there
i am using cadence IC 5.141 and i want to add the tech. parameters to the resistors in my design i already have a TSMC 0.18 model card (.scs) whcich contains resistor corner model , but i don't know how to attach this model parameters to my design
thanx in advance
WA
did u try to do the same steps as in Transistors?
btw when i close the schematic and reopen it , i have to re-add the model card path again , cannot this step be automated?
thnx
    ramy_maia
safwatonline said:
WA
thnx
by save state i think,from here another problem arises,,,when i save state,,and then re-open cadence again ,i found no saved states although i noticed a folder in the workspace called simulaton which contains i think the states i simulate
any suggestions?
thanks
    ramy_maia
AA,
ramy check the model card as pdf , then in page 14,15 there are like 10 model names for diffrent resistances try to see which one u want to use then add its name to the model name of an ordinary resistance from analog library
    ramy_maia
any suggestions?
thanks
very strange i save states just as you said and i still have them but you must load state of the same cell view you saved not another one
