How to add a new material to HFSS 9.1?
y
Newbie level 5
Adding a new material
Hello,
I want to add a new material to HFSS 9.1.
How is it done? What are the parameters needed for the program?
Thank you.
Re: Adding a new material
I'm not sure about 9.1 but in 9.2 you can add new material in following way:
select 3D Modeller -> Assign Material -> Add Material
You should check at least relative permittivity property, probably also dielectric loss tangent. Other properties are relative permeability, conductivity and magnetic loss tangent. Magnetic saturation, Lande G Factor and Delta H are ferrite properties.
Search from Help -> Contents "adding new material", you'll find more explanations from there.
regards,
Markus
Reactions: Hasan7
    Hasan7
