How to access the cgram of lcd ?
newbie111
Member level 2
h.k
cgram again
I tried to access the cgram of my lcd
but nothing happened
LCDSCGA
               ANDLW  0x01
               iorlw   0x08
                call lcd_c
store
         movlw   0x40
         movwf  0x00        ;Load row 1 data
         call lcd_c   ;Send the data
         movlw  0x0E
         movf  0x01      ;Load row 2 data
         call lcd_d   ;Send the data
         movlw   0x0E
         movwf  0x02          ;Load row 3 data
         movlw   0x0E
         movwf  0x03           ;Load row 4 data
         movlw   0x0F
         movwf  0x04       ;Load row 5 data
         movlw   0x00
         movwf  0x05        ;Load row 6 data
         movlw   0x04
         movwf  0x06       ;Load row 7 data
         movlw   0x00
         movwf  0x07        ;Load row 8 data
         return                 ;Return from routine
Actually I do not know how to make it work
I am poor in programming.
Would anyone kindly teach me how to store a font into cgram
Thanks
Re: cgram again
Which display driver are you using?
Is it a graphical display or a character based display?
For example, in the CGRAM of a HD47780 compatible display driver, the display font is fixed in ROM, and only a small RAM-space is left to define your own characters (only 8 characters can be self defined).
A simpler language for programming is e.g. C. If you look around on the internet, you can find several good libraries for communicating with an LCD display, written in C. These can safe you much time.
    newbie111
Re: cgram again
ihave a character based display
thanks for your answer
but my codes are all written in asm
Re: cgram again
Be aware that programming in assembler is often much harder than programming in a higher level language such as C. Personally, I would not write routines for driving a character display (with onboard display driver) in assembler, since the timing is not an issue, and some basic display-related stuff such as writing strings and integers to your display are not easy to write in assembler and will take a lot of programming time. In C, there are a lot of libraries available which can do all the hard work.
Is it a HD47780 based LCD display?
    newbie111
Re: cgram again
Is it a HD47780 based LCD display? Yes it is
i will look at c programming too
thanks a lot
