reduce the windings Nr on the secondary side-if you can, but you must measure the sec-voltage under your real load conditions pls!
Otherwise you must take/select a new one :-(...
K.
K.
You see, if you are hungry;: you wish to eat some thing an does not go sleep and so on
I mean, if you need lower sec-voltage, you van change the windings on your trafo or the trafo self_thats life...
K.
K.
To ruduce the outlet voltage , you can use 2 resistors.
Apply the outer voltage to the " 9+8=17 " resistor , and therefore you'll be able to get an output of 9 volts from the " 9 " resistor.
I didn't fully get what you mean.
Do you mean that we cannot apply high current to this resistors !?
Well , I think we can use high-power resistors , can't we !?
Its so; elmahboule didnt tell us how much power he needs, but thes is a transformer, so a thing is usually with some watts loaded, also the resistors are for that to dimensioned & packaged ...
I think you can agree with me.
K.
