For example, if you have a signal centered at 200 MHz with 30 kHz bandwidth, and there's no signal outside that bandwidth, you can sample it at slightly over 60 ksps without losing any information. If you wanted to, you could convert the sampled data back into the original 200 MHz signal
A.Anand Srinivasan said:nyquist criteria specifies only the minimum sampling frequency required... hence there is no contradiction.... also higher sampling rate means better resolution,,,,,
