How the multi bit flip flop will be design ?
Muthuraja.M
Full Member level 1
Hi friends,
I want to design a multi bit flip flop by using single bit flip flop ?
Tell me is it possible ?
Pls reply me with the key ideas that how to design ?
yes it is possible. design a dff in verilog or vhdl instantiate it in a top level module to any number of bits u want.
I need help in coding in vhdl for multibit flip flop design.
Can any body give VHDL Code for master slave D flip flop with two inverters, using behavioral modeling ?
Talk about being lazy...
1. Resurrect a 6 month old thread! Oh, I can't create my own thread, that's too much work.
2. Then ask for code (multi-bit flip-flop) that you can find examples of, if you use a search engine! Oh, that's too much work!
3. Resurrect the same thread again after 8 more months pass! Create my own thread, whoa, that is really way too much work, I'd rather use the one I bookmarked!
4. Ask another question that you can find by using a search engine. Of course you may have to use some grey matter to translate the circuit to behavioral VHDL. No way! do work!, use my brain!, why would I ever want to do that? I'd rather just leach my answers off of edaboard.
So I guess I'll be just as lazy with my answer and just point out your lack of effort.
I am a newbie to vhdl and i thought it better to resurrect the old post since it was related and there were no answers.
I am working on MBFF, I did the code for master slave in structural model using two inverters and two D latches, but i am not sure how to use the sytem clock , Since I want to find the clock power consumption, and since i consider myself a beginner I posted the same. any help would be appreciated.
lol..yes @dhanya22,you should have to go through the forum rules once.
anyways, this might help you - **broken link removed**
i want it in behavioral modelling style
