How the bit rate is related to channel bandwith?
magnetra
Full Member level 5
27.45N, 85.20E KTM, NP
Bandwidth
This is in reference to a section in Modern Digital and Analog communication by B.P Lathi.
The author states, in digital communication, fundamental basis of determining bandwith is "Two signals without error can be transmitted per sec per Hz"
In fact I'm confused how the bit rate is related to channel bandwith in Digital Communication? Anyone please explain.
Magnetra
sameerbabu
Member level 3
Re: Bandwidth
According to Nyquist theorem
theoretical maximum u can transmit is 1 symbol/s in 1 Hz band
u may be knowig symbol/s and bps relation
magnetra
Full Member level 5
Re: Bandwidth
Hmm the Bandwidth required in Digital communication doesn't seem to be related to the message as in case of Analog Comm'n. But I don't understand how the bandwidthis determined in Digital commn
Any place on the net which has a good explanation.?
Magnetra
magnetra
Full Member level 5
Bandwidth
Is the question too trival to be bothered about or is it a tricky one??
Some views please.
Magnetra
rednewguy
Full Member level 2
Re: Bandwidth
in digital communication, the channel bandwidth only depends upon the bit rate. take u r going to represent 0 and 1 using NRZ coding. 0 with negative pulse and 1 with positive pulse.
the frequency domain characteristic of a rectangular pulse is sinc, which means u need frequencies of (- infinity to + infinity) ---> infinite bandwidth
in practice we use raised cosine to represent 0\1s which takes only main lobe of the sinc function.
reduce the pulse width(increase bit rate), main lobe size increases(increased bandwidth)
mro83
Member level 5
Mashad
Bandwidth
in the information theory u have the Shannon's theorems.
it states:
C = BW. log(1+SNR) i.e; capacity of the channel is related to bandwidth and SNR of the signal and noise.
and capacity is related to Hs (Antrpy of the source ) and Rs (Symbol rate).
for more detailed discussion refer to "digital communication " books. or the essay in this link :
cheers
