use chipscope core in your design to see the signals generated in hardware, you can see if everything is generated well or not
so what if chipscope is tracing the I/O signalS? right! in that case, it can verify what is in and out of FPGAChipscope will do absolutely nothing to verify signal levels on the I/Os; it will only verify internal logic.
i think if the output ports are assigned to some input pins in that case chipscope can track them, I'v done this to verify the signals on Ethernet phy layer chip,NO!
Chipscope can verify what logic signals are at the internal side of the I/O buffers, it CANNOT verify what's coming out on the pins.
