How t o convert Gerber file so that it can be read by OrCAD Gerber tool?
real_tr
Member level 3
Turkiye
Hi all,
I have a schematic and i send this schematic to one of my friends to create its pcb design and he sent me its gerber file
i use orcad 9's gerber tool and i cannot open that gerber file with orcad :cry:
i think he create that gerber file wth mentor's tool
how can i convert that gerber file that i can read it with orcad's gerber tool ? :?:
is there a way ?
MeCeX
lennonwang
Newbie level 5
gerber türkiye
I usually use Cam350 tool to check and modify the gerber file. It needn't limit in OrCAD gerber tool.As long as the gerber file generated in Gerber600 or Rs274x etc. general format, general tool could read in.
binu G
Advanced Member level 2
Bangalore
gerber problem
i got a problem in gerbtool 13
after importing the file i found nothing wrong in the job.i exported the gerber to gerber format. now when i imported i found some extra circles present the in it. what is the reason behind this
binug
real_tr
Member level 3
Turkiye
gerbertool, pcb design
thanx
i solved the problem
i like gerbtool really good program
MeCeX
binu G
Bangalore
edit modify gerber tool
but be careful mr real_tr
some time the output have the errors. too.
i experrience very badly
binu g
real_tr
Member level 3
Turkiye
the geber problem
what type of errors
can you explain ?
which gerber tool do you use now ?
MeCeX
binu G
Bangalore
Gerber Problem
like the extra circles commming in the output gerber.
also some data missing etc while exporting.
binu g
real_tr
Member level 3
Turkiye
Gerber Problem
really missing some data ?
too bad
which tool do you use ?
MeCeX
binu G
Bangalore
Gerber Problem
after that i started using the cam350
it sound better than the gerbtool 13 but gerbtool 10 is better. was having less bugs
binug
lyric
Junior Member level 1
Gerber Problem
I think CAM350 is better than GerbTool
hcet
Full Member level 5
Re: Gerber Problem
to real_tr:
i made good experiences with isopro
