dmmahesh
Junior Member level 2
If we invert 12Vdc into 220Vac, 50Hz what extend of current (Amps) we can use from the output. Say it is 500W means we may use upto 2Amps., is it right, after getting that output is it possible to stepup up into higher current rate upto 8Amp with same 230Vac? If so what can we do with the transformer or circuit and what would be the forumla we've to use? Please kindly give me in detail
