patrickian01
Member level 1
- Joined
- May 17, 2013
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,626
I created oscillators ranging from around 13MHz up to 25MHz and the voltage levels read from an oscilloscope range from around 800mV pk-pk to 1.2V pk-pk. I plan to transmit them using quarter wave monopoles over a short distance of around 8 meters. How much pk-pk voltage do I need to transmit these frequencies 8m across? I tried building a common emitter amplifier using a BC547 but for some reason, it didn't work. Any help on the amplifiers would be much appreciated as well, and I would like to know how much voltage or current is needed for the operation above and how is it computed? thanks in advance.
