How much does an aluminium enclosure wrapping improve the Radiated EMC test?
treez
Advanced Member level 5
cambridge
Velkarn
Full Member level 3
Hi!
from my expirience in EMC testing of power supply with and without aluminium case, ps in case produces less conductive emi, cant remember numbers, but significant. So i think, in radiated emi will be the same
dick_freebird
USA
I think it depends on the case return path (how good,
and to where) whether it acts as a shield or an antenna.
treez
cambridge
Thanks, yes, and i believe that it depends to which node on the circuit it is connected to. eg preferably a quiet node and preferably ground. If its an offline SMPS, then you wonder whether to connect it to earth , or secondary ground? Also, prefereably it only connects to the circuit in one place only?
I also wonder if a carbon fibre covering would be as good.?
LaTeX Commands Quick-Menu:
