Register Log in
How many MOS transistors are required to implement full adder?
xstal
Full Member level 2
USA
Re: INTERVIEW QUESTION
Refer Kang or Rabey, The logic is implemented such that the carry logic is reused in sum logic. Hence the number of transistors are minimum.:|
Added after 33 minutes:
Refer Kang, The logic is implemented such that the carry logic is reused in sum logic. Hence the number of transistors are minimum.:|
Arturi
Member level 2
A full adder has 2 XORs, 2 ANDs and 1 OR gate.
Each XOR has 2 ANDs and 1 OR and 2 INVs
So we have a total of 6 ANDs and 3 ORs and 2 INVs
ANDs and ORs use 6 transistors in CMOS, INVs use 2 transistors
So, 6*(6+3) + 2*(2) = 54 + 4 = 58 Tranistors
Hope I got that right!
cheers
bhanuriramesh
Newbie level 6
min num of 28 transistors are required to omplement fulla dder
alpeshchokshi
Full Member level 2
San Jose, CA
can you explain me how u reached to the 28 no. transistors????
Jyotshna Mamillapalli
Junior Member level 3
Try with pass transistors
For sum you need 6 transistors
bhanuriramesh
Newbie level 6
we cant implement a fulladder sum with 6 transistor....
min num of transistors req r 28.........................
can u explain how do we acheive using 28 transistors?
Zeng Jie-jun
See Picture.
smalldog
Junior Member level 2
What kind of job interview were you done for this questin? Layout position, or designer, or system manager
xstal
Full Member level 2
USA
28 transistor solution is the optimum. This is the same solution that I suggested (refer Kang). It is reusing the carry logic to obtain sum.
cnspy
Full Member level 3
INTERVIEW QUESTION
full custom design
sumit_techkgp
Full Member level 2
INTERVIEW QUESTION
It depends on your delay and power requirement
Sumit
Mehdikhantan
Newbie level 3
14 of the cmoses are enough
See the picture attached
subbuindia
Member level 5
Vellalacheruvu(AP), India
Hi friend....
Can you explain how this circuit gets the outputs of full adder? Of course, I didn't check all conditions. Suppose I take A=0, B=0 and C=1. Accroding to this inputs we have to get the carry output is 0. But, in this circuit we get, 1.
Even, Why you are using A xor B as input for carry output?
Mehdikhantan
Newbie level 3
Hi friend....
oh
excuse me
there is a mistake in the picture
A XNOR B Is correct
try that;)
Toggle Sidebar
