How long one charector will take in 9600baud ?
ScrewDriver
INDIA
hello
How long it will take for one byte ( 1 start bit, No parity,1 stop bit) in 9600 baud?
As far as I understand it is (from some searches in google)
9600/(8+1+1) = 960 bytes/ second
So one byte will take 1000/960 ~ 1 millisecond.
So if interrupt enabled for serial port in a MCU and data is coming in 9600 baud ,serial interrupt will appear in 1 millisecond gap.
is this correct?
Thanks
SD
zorro
Argentina
Correct (when data are coming continuously).
But if the UART has buffer capability, MCU can service it less often .
Regards
Z
one bit takes 1/9600 s= 0.00014 s
8+1+1=10 bits takes 10x1/9600=1.04 ms
so you'r rigth !
drbizzarow
Advanced Member level 1
u r writ what controller u r using ?
penoy_balut
Full Member level 2
Wrong.
USART has independent Receive Shift Register, when reception is complete it will then notify the processor by setting RCIF, if interrupt is enabled, it is the interrupt service routine that takes processor time not the serial data reception.
funnynypd
Banned
USA & Canada
if a sw UART is used, then it will take some processor time and probably a dedicated timer.
ScrewDriver
INDIA
penoy_balut said:
Wrong.
My intention is to know the time available for the ISR to read data and then for the other routines to process it before the next one arrives in a hardware serial port peripheral.
it is 1 ms in 9600 baud !
SD
penoy_balut
Full Member level 2
of course 9600 baud is approx. 1 ms but it does not mean it will take 1 ms of your processor time (even a sw uart will not) or you only have 1 ms to process data, it depends on your programming style
sami123qa
8 bit for the character and 2 for starting and finish bits the total is 10
sense in 1 second 9600 bit can be transfered ,in ?? can 10 bit transfer
10/9600= 0.00104 sec
