how inject 1mW power to antenna
spide
Member level 3
Member level 3
can anyone guide me how i can inject 1mW of power to the antenna for testing purpose.
Connect it to the network analyser (VNA) and set the output power of 0 dBm which is equivalent to 1mW. Please see reference below.
I think he is trying to say "how do I get 1 mW of power into a system with an antenna attached to the front end".
Well, you need to get another antenna, put much more than 1 mW into it, point it at your receive antenna, and somehow calibrate the mess so that 1 mW is received into the antenna's effective aperture.
u mean, i could just use a RF signal generator to set the power of 1mW n connect it to the antenna?
If your question is what I think it is then yes, it is as simple as that.
However, biff44 did get me rethink a little. If biff44 is right, then his proposed method should be considered.
