how import orcad sch netlist to ultiboard pcb???
senthilkumar
Advanced Member level 1
india
import .sch to orcad
hai,
i draw the circuit in orcad.
i want to draw pcb in ultiboard.
how can i import the netlist and what format the ultiboard support.
asterix91
Member level 5
ultiboard orcad
If you have Ulti board why dont you check what netlist input types does it take.
Frosty
Full Member level 6
EARTH
netlist format to import ub netlist
Which version of UB, which version of Orcad.
Up to UB5.7 UB could only import < SDT IV netlist and only using command line utility on CD to convert netlist to net/plc files. It was called ORC2UC.exe I think.
You also needed to have SDT installed with the enviroment set for lib paths and all other SDT stuff.
I never got it to work right.
For latest version I beleive you must use UC or MSIM to import SCH then use UC or MSIM exported utility to create netlist for UB.
UB is a nice SW but it would be faster to learn Orcad Layout than make a netlist by hand although as both the .net file and the .plc & .net file are ASCII you could use a text editor & some macros to convert yourself.
Just make sure you have valid names in the UB PCB library before import.
Oh dear UB, seems a long time ago now.
:R
Frosty
Full Member level 6
EARTH
orcad.sch
Forgot
If you make netlist make sure all names comply with max 8 char names and no illegal characters like space and so on. UB will just cough and die if you do this (This program has performed and illegal .....)
:R
