how Ichose ferrite core
Alian
Junior Member level 1
Hi for all Iwant to ask and help how Ichose suitable of ferrite core for any application that Iwant to make it (example) etd ec ee and ei cores And how much power (watt) that we can get from ETD49/25/16 and EC49/27/17 on 100Khz frequency and what is the different between EC and ETD cores because iwant to make inverter welder mashine and Ihave the two cores that Itold of them from china tv please any one help me and thanks for all
Reactions: FvM
    FvM
Thank you mr peter ETD49 suitable for welder mashine 15volt 80ampere output and 220v AC input and how many numer of turns for primary and secondary on 80Khz
For welder device you should use copper strip specially for secundar.
See this project:
Welding inverter up to 100A
http://danyk.cz/svar_en.html
Best regards,
Peter
Reactions: FvM
    FvM
thankyou very very very much mr peter and I want to answer me how much power that I can get from ETD49/25/16on80Khz because I want to make mini welder 70-80 ampere and Ican not to found the core in the circuit that you put it
Switching transformer Tr1 is wound on two ferrite EE cores, each with a central column section 16x20mm. The total cross section is therefore 16x40mm, the core must have no air gap. 20 turns primary winding is wound using 14 wires of a 0.5 mm diamater. It would be better to use 20 wires, but they didn't fit to my core. Secondary winding has 6 turns of copper strip 36x0.5mm.
Reactions: FvM
    FvM
what about ETD49/25/16 Iwant to use it how much power
How can you possibly expect to make a SMPS welder with zero knowledge about SMPS. I see smoke in your future.
  • MagneticsAreaProductDistributionChartWaAc2012.pdf
  • MagneticsTypicalPowerHandlingChart2012.pdf
  • TransformerDesignWithMagneticsFerriteCores.pdf
Hi mr Flapjack Iput my questions because I want to learn and to know because If Iknow Idon't put my qustions and you have to be careful when you want to put your reply!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! thanks
Thanks mr tpeter for your information and your help
Alian, if you want to learn then start with a LOW power SMPS. You are going to burn up a lot of components and this will cost a lot of money if they are high power mosfet's.
hello peter u given very good data of welding machine is it commercialy succesfull?
