How IC Design Works?
pragash
Advanced Member level 2
Oakland
I'm new to IC design. I would like to understand how IC design (RFIC and MMIC) works. PDK will have active and passive components. Do we just use those components as it is and create interconnects between active and passive components? Can we create our own passive and active components?
Excuse my stupid questions because I'm inexperienced.
Not a stupid question.
What I´d do:
* internet search "how IC desing works video"
* or similar.
* or a youtube serach.
I guess a video can give a useful overview.
Klaus
You can create some components which are not included in PDK. Some devices are not modeled or extra price if you want to use, but you can try to create layout and model them, but last is quite difficult I think.
For passive an example is the MOM cap, which doesn't support to use all available metal layers sometimes, or its breakdown voltage is not what you want and you can adjust horizontal distance between plates, but PDK usually doesn't let these as default option.
For active an example is the standard logic cell library, which is not given sometimes, or cell types are limited, contacts limited, etc. and you can set/create those.
And actually there are some tutorials available where people create layout first of circuits then schematic of the instance. LVS is smart enough to recognize active and passive devices. So, I can imagine maybe it is possible to create a donut shaped MOS for example if you want, until its layers can be recognized in the correct sequence.
Other question is how can it be manufacturable, unfortunately I have no experience with it. Maybe donut shaped CMOS is a default device in PDK, I have no idea about, it has just got into my mind.
