arecssor
Junior Member level 1
i want to take power from a 12v 7 ah battery to 3 watt led board (the led board contains 50 units of 2 led connected in series linked in parallel
along with a 56 ohm (please ignore the 470 ohm ) in series as in the image .when i use 7805 to reduce the voltage the ic is getting very hot , how can i powerup the led box without heating the 7805 ic and with high running time .
