The receiver output is 0V to 9V which is too high to safely connect to a TTL input, I suggest you take the output through a resistor of 470 Ohms to the input of the MAX232 and add a diode from the MAX232 side to it's 5V supply, cathode (+) end toward the 5V supply. This will protect it from excessive voltage.
The inputs (from the receiver) to the MAX232 are on pins 10 or 11, use the appropriate output to the PC and Hyperterminal or some other similar software to see the data.
