How does Vds change over temperature? ?
gggould
Member level 3
Hi all,
If I have a diode connected NFET being biased by an ideal current source. As the temperature goes up, based square law, the Vds now equal to Vgs should go up too. But my Vds versus temp simulation result is actually opposite. Does anyone know why?
Also, in this configuration, how does the Vdsat change over temperature?
Thanks
gggould
checkmate
Advanced Member level 3
Toilet Seat
Why would you think vgs will increase with temperature based on square law?
vgs = vth + vov
Threshold has a negative TC typically around -2mV/K. As for overdrive, it also reduces with temperature due to increased mobility.
gggould
Member level 3
Thanks for the comment.
Id=0.5UnCoxW/L(Vgs-Vt)^2
As temperature increase, Vt decrease and Un decrease (due to scattering), so Vgs (or Vds in this case) should increase, isn't it ???
