D(0,1,2) =0 Q(0,1,2)(t+1)=0 operation= reset
D(0,1,2) =1 Q(0,1,2)(t+1)=1 operation= set
This means that the DFF output will be 1 whenever the condition was set(D=1).
there is no input in to the DFF that produces a "no change" condition. This condition can be accomplished either by disabling the clock pulses or by leaving the clock pulses undisturbed and connecting the output back into the D input using a multiplexer when the state of the DFF must remain the same.
The DFF is a storage element. It stores its value on its output. Its output value is updated with the input value at every clock edge (either rising or falling). It is an important element because it allows for synchronous circuits, ie where value changes are synchronized with clocks.
