Euler's Identity
increase distance infrared
I'm perplexed!
How can the infrared transmitter for my television control the television from 10 yards away, when it uses only two AA batteries, but a transmitter of my design, which uses near 300mA (when pulsed on) can't make it past two yards? Plus, I think I'm also losing transmitted power due to heating, to boot.
Is it lenses? Is that what I need to make this thing work? If so, where can I get such lenses and how do I choose them? Do I need two, one for the tx and one for the rx? The tx lense spreads the ir after the LED and the rx lense compresses the ir before the transistor??
I'm missing something somewhere. How do I get distance that's worth a hoot?
Incidentally, the design is based on a 40KHz PLL transmitter (cd4046) w/VCOin locked and a 40KHz PLL (74hc7046, a 4046 w/lock detector on board) receiver with a linear pre-amp at the front end. The design works great, electronics-wise, but the opto part is very lacking. I just can't seem to get any distance to speak of and alignment is rather difficult at best.
Added after 8 minutes:
tx ir D = OP290A
rx ir Q = OP599A
Incidentally, it'd be great if someone out there could give a link to education with working with lenses to solve infrared communications problems. At a couple feet I'm good, but at >two yards I'm in the weeds.
Thanks.
I'm perplexed!
tx ir D = OP290A
rx ir Q = OP599A
Thanks.
